Voicemail Notification Will Not Clear
This is a discussion on Voicemail Notification Will Not Clear within the LG Ally Help forums, part of the LG Ally category; I've tried all the fixes I can find any my VM notification still will not clear. Someone please help!...
Results 11 to 13 of 13
Thread: Voicemail Notification Will Not Clear
    Android Lurker mswjaw's Avatar
    If you've tried everything posted here, and it's still there, call Verizon or take it to a Verizon store and have them fix it.
    Only fix is to do a factory reset to your phone. This happened to me 2 weeks after I purchased my phone. I searched the forums, talked to people and called Verizon. Nothing worked. Did the factory reset and it worked. And my phone ran a lot better afterwards too. I know this reply is a little behind but I still wanted to post it for the next person that has this problem. Thanks.
can you turn off voicemail notifications on an lg ally
cell phone voicemail notification wont clear
clear voicemail notification android
how to clear notification that wont clear on s4
how to clear voice mail icon stuck on galaxy s4 phone
how to clear volcemail icon on lgvm670
how to delete voicemail icon off lg ally
lg ally voicemail notification
lg enlighten voicemail notification
lg g2 voicemail notification won't clear
lg p690f won't clear notification
my new voicemail will not clear off my android phone
new s4 has voicemail indicator that wont clear
voice mail icon on my lg enlighten cell phone won't stop loading
voicemail indicator will not clear on lg enlighten
