Voicemail Notification Will Not Clear
This is a discussion on Voicemail Notification Will Not Clear within the LG Ally Help forums, part of the LG Ally category; Hello ... Suddenly, my voicemail notification icon won't clear after I've listened to and deleted the voicemail message. Has this happened for anyone else? Any ...
Results 1 to 10 of 13
Thread: Voicemail Notification Will Not Clear
    Android Lurker BernardDogs's Avatar
    Hello ...
    Has this happened for anyone else? Any fixes?
    Thanks,
    BD
    There is another thread about this. I would post the link but I am at work. Try a search.
    Yeah ... I've tried a search and I'm not finding anything. I'll poke around more. In the meantime, if anyone has the link mentioned above or any thoughts ... I'd be very appreciative.
    4 hours later, it seems to have righted itself.
    I know there was a solution but I can't remember what it was now and can't seem to find the other thread either.
    Android Jr Member amazinz5's Avatar
    i'm having the same problem and just looked through 7 pages of results...if anyone remembers the solution would you mind reposting it here or directing me to the thread?
    I had a delay once but not 4 hours. I recalled my voicemail and made sure she said, "There are no messages in your mailbox." The notification was still there a few seconds after but just as I was going to turn off and restart the phone, it cleared. I guess I imagined the RAM is like the old Windows OS that needed a restart every now and then. For something like that I begin to troubleshoot with a restart and hope...
    I have not verified this, but it's worth a try, it only takes a minute. If the voicemail notification gets "stuck" try returning to the homescreen, and gently taking the battery out while the phone is still on, wait a minute or two, then put the battery back in and when the phone boots-up, dial *228 and choose option 2 for the roaming update. The phone should restart and the notification gone.
    I had a Facebook Upload freeze and stay in the Status Bar a long time. I just powered down and restarted the phone. It was gone when the screen returned.
    Android Lurker jal7884's Avatar
    Selbyville,de
    i had that happen to my ATT envoy. i called and left my self a message and when i listened to that message it cleared. Actually the first time it happened i called 611 and they did the call/message thing. it's only happened once since. never happened on my ally.
can you turn off voicemail notifications on an lg ally
cell phone voicemail notification wont clear
clear voicemail notification android
how to clear notification that wont clear on s4
how to clear voice mail icon stuck on galaxy s4 phone
how to clear volcemail icon on lgvm670
how to delete voicemail icon off lg ally
lg ally voicemail notification
lg enlighten voicemail notification
lg g2 voicemail notification won't clear
lg p690f won't clear notification
my new voicemail will not clear off my android phone
new s4 has voicemail indicator that wont clear
voice mail icon on my lg enlighten cell phone won't stop loading
voicemail indicator will not clear on lg enlighten
