clock screen randomly popping up
This is a discussion on clock screen randomly popping up within the LG Ally Help forums, part of the LG Ally category; Ok so I've had my ally for a little while now and I love it, but recently everytime I plug my phone into the charger ...
Thread: clock screen randomly popping up
    Android Lurker JRuple's Avatar
    Ok so I've had my ally for a little while now and I love it, but recently everytime I plug my phone into the charger the clock screen pops up like every 15 seconds. (The screen with the alarm clock options, home key, music key, etc) it doesn't matter what I'm doing, but as soon as I plug it in, it goes bonkers. Any suggestions, or have you heard of this before? I'm ready to run my phone over with my car...
    Thanks!
    Quote Originally Posted by JRuple View Post
    Thanks!
    This is something that is normal if you are plugging the phone into a desktop charger. Other than that it shouldn't happen.
    No this is the wall charger and it only happens when its plugged in...I have factory reset my phone 3 times and no luck. Could it be the charger itself? I've checked all cords and everything is secure. Its driving me crazy especially since I love my phone!
    I don't know. I cannot think of any reason why it would do this with just a wall charger. I do not know of any settings that you could adjust to stop it.
    Some Apps have an option on how to respond while charging. I have seen Keep Screen On as an option. Maybe you have such an app and it is conflicting with phone settings. But after a Factory Reset maybe not. Perhaps your connections are not being made. It sounds like something similar I have experienced with an old phone. But the Ally is set to turn on when charging so maybe it is starting and stopping the charge and hence, the phone. If it is a faulty USB cable, it should fall under warranty.
android alarm clock keeps popping up
android alarm keeps popping up
android clock app keeps popping up
android clock keeps popping up
android desk clock keeps popping up
android world clock pop up
desk clock keeps activating
desk clock keeps popping up on on samsung
desk clock keeps popping up s3
galaxy s3 desk clock keeps opening
how to stop desk clock from coming on
samsung galaxy s3 desk clock keeps popping up
why does my phone keep going to desk clock
