I was wondering what this was about if it was free and if it is good thanks.
This is a discussion on divX VOD Restestration within the LG Ally Help forums, part of the LG Ally category; I was wondering what this was about if it was free and if it is good thanks....
So far I have had no luck getting the DivX registration or DivX to work properly on my phone. I have gone through all of the steps about 5 times and each time I play the registration video on my phone, it plays fine. But then when I try to play a DivX movie, it doesn't work and then it seems to unregister my phone because the registration video will no longer play either. So then I have to go back and re-register the phone and the whole problem circle starts again. After 5 times of trying, I just gave up.
I never ran the registration video on my ally... they play fine
Try not playing that clip... just use a standard dvix file from the get go
O and remember not all dvix files are created the same... you may not be able to play a component within the dvix format
