phone went out with a bang
This is a discussion on phone went out with a bang within the LG Ally Help forums, part of the LG Ally category; Yea my ally is on its last legs... yesterday I had it overheat and make 2 sets of cracks appear on the glass... I'm just ...
Thread: phone went out with a bang
    Android Jr Member angelfire123's Avatar
    Yea my ally is on its last legs... yesterday I had it overheat and make 2 sets of cracks appear on the glass... I'm just wondering if its supposed to work as it still does
    It got so hot that it cracked the screen? Wow. I would have to take it to Verizon for a new one. The phone should shut itself off before it overheats enough to damage the phone. I am surprised that it still works.
    the 2 stores i took it to wouldn't touch it... i think it has to do with the glass being as comprimised as it was... the 2 reps that considered looking at it went looking got gloves lol... as of tomorrow i move along to the Motorola Dtroid 2 as a phone rep for some reason told me to claim it under the worry free guarantee and be happy
    Greenville SC
    Wow -- Angelfire, if I had your Verizon rep, my Ally would overheat and break the glass, too! So you get a free upgrade to the D2? I'm envious. Or should that be enV-ious?
lg ally phone screen went out, but phone still works
