phone wont make calls
This is a discussion on phone wont make calls within the LG Ally Help forums, part of the LG Ally category; hey i recently got this ally and it was working well for me up until it started failing to send my texts. now its gotten ...
Thread: phone wont make calls
    Android Lurker glentennis's Avatar
    hey i recently got this ally and it was working well for me up until it started failing to send my texts. now its gotten worse and it wont make calls or send texts even in areas where i know i have great signal. im also getting that "100% without signal" message for the cell standby and it isnt even able to connect to *228...
    has anyone had this problem or should i just bring it in and get a new one?
    You bought your phone to make phone calls with?
    You should take the phone in and have them run some tests on it.
    Android Lurker Pitt87's Avatar
    When I unlock my Ally and press the telephone icon on the far left, I receive the message The application LG Home (process android.process.lghome) has stopped unexpectedly. Please try again. Force Close. I have done this numerous time, shut the phone off, restarted and taken the battery out to no avail. I have deleted all my apps that I've downloaded, still no luck. Any advice?
    Android Jr Member blay's Avatar
    Can you try changing themes?
    If switching home themes doesn't work do a factory reset.
android phone cannot dial or receive a call
android phone won't call out
android phone won't let me dial out
lg b450 cant call out
lg phone not making calls
lg phone won't dial out
lg phone won't make calls
lg phone wont call out
lg phone wont make calls
my lg phone wont let me make calls
my lg phone wont make calls
my t mobile lg phone wont make calls
tmobile help phone will not let me dial out
why cant i make a phone call with my lgg3phone
why won't my phone make calls
