random apps running
This is a discussion on random apps running within the LG Ally Help forums, part of the LG Ally category; I recently discover the "task killer" and I'm very thankful for it. It's unfortunate that such a utility is needed, but... My question is, what's ...
Thread: random apps running
    Android Lurker scottyhuff's Avatar
    My question is, what's the deal with random apps running in the background? For example, just now I checked the Task Killer and it told me that VisualVoiceMail was running even though I have NEVER used it. Is there something causing this? Do all Android phone have this problem? Is there a setting I can... set... to keep this from happening?
    Thanks in advance! :-)
    ...Scotty
    Quote Originally Posted by multiguy View Post
    ...Scotty
    Yes all Android phones do the same thing. There certain apps and processes that the OS spawns when it sees that they are not running, and you can't stop them, other than to Kill them, which is questionably safe. The Android OS should manage them and suspend them when not needed, requiring little or no memory... But as we have seen, this does not always happen... I think Android 2.2 will only have more stuff running :-(
android random apps running
apps keeping starting on lg thrill
close running apps in lg thrill
how to fix lg thrill random apps opening
how to stop apps from running in background lg thrill ?
kindle running apps randomly
lg ally stop running programs
lg thrill applications keep running
lg thrill background apps
lg thrill how to keep applications from running in the background
lg thrill open apps randomly
lg thrill update apps running without permission
my apps keep running even when i kill them on my dna
stopping background tasks on an lg thrill
why do random apps keep running
