Connection Error with email
This is a discussion on Connection Error with email within the LG Ally Help forums, part of the LG Ally category; My LG Ally is no longer receiving my emails. All other apps work - web, text, phone, FB. I have tried turning it off and ...
Thread: Connection Error with email
    Android Lurker tmedina's Avatar
    My LG Ally is no longer receiving my emails. All other apps work - web, text, phone, FB. I have tried turning it off and on. I have checked both my incoming and outgoing server settings. I only have the one account with Roadrunner. Nothing seems to get my email going again. This same thing happend to my husband's Ally about two weeks ago with his Roadrunner account and he deleted the email account and reinstalled, but in doing this he lost all his contacts. I do not want to lose my contacts. Does anyone know what could be wrong with my phone? Thanks.
    First question, are you using a task killer?
    Also, by contacts, do you mean the phone contacts?
    Sorry - but what is a "task killer"? This smart phone thing is very new to me.
    Yes - all his phone contacts were wiped out, names & numbers that were transfered from his previous phone.
    Nevermind on the Task Killer. If you don't know what one is then you don't have it installed.
    Also, you can delete your Roadrunner email account without deleting your contacts. They should not be synced.
    Android Jr Member Venez68's Avatar
    Jersey Shore
    i have three email accounts set up and the only one i have a problem with is Yahoo if i turn on my wii-fi connection.
    for some reason it says username/password incorrect and never loads any messages. it never deleted any contacts though.
    if wi-fi is turned off and i'm on 3g no issues with receviing emails.
    "STAY THIRSTY MY FRIENDS"
    For Yahoo, I would probably just use their app which you can download from the market.
    Android Lurker zhangfi's Avatar
    I was getting the same error. I verified it wasn't my task killer, re-installed e-mail and nothing worked. I read that sometimes it can be an actual e-mail causing the issue so I setup a new folder on my roadrunner e-mail account and moved some e-mails from Trend Micro system there and poof ... e-mail started working. Not sure if this was the actual issue or a coincedence but you may want to try that.
android email connection error
android outgoing email connection error
android yahoo mail connection error
connection error android email
connection error email android
connection error on outgoing messages on android phone
email app in android shows connection to server errors
lg ally connection error email
lg enlighten connection error
lg enlighten email connection error
not receiving emails on lg enlighten
roadrunner android connection error
roadrunner email on android connection error
server error email lg phone
server error sending email on lg phone
