Need help deleting a shortcut on desktop
This is a discussion on Need help deleting a shortcut on desktop within the LG Ally Help forums, part of the LG Ally category; I am wondering how I can delete desktop shortcuts on Android. I have connected the phone to my computer and deleted all Zedge related material ...
Thread: Need help deleting a shortcut on desktop
    Android Lurker cfcid's Avatar
    I am wondering how I can delete desktop shortcuts on Android. I have connected the phone to my computer and deleted all Zedge related material AND restarted my phone and it still has not worked.
    Greenville SC
    Touch and hold the shortcut until a trash can appears at the bottom of the screen. Drag it into the trash can. To uninstall the app, go into settings>applications>manage applications, then open the app you want to delete and touch "uninstall" and follow the prompts.
add shortcuts on the lg connect
delete short cut on lg ally
disable app shortcut lg
how do you delete shortcuts on my lg ally
how to delete shortcuts lg connect
how to delete shortcuts on lg connect
how to delete shortcuts on the lg connect
how to remove shortcup lg connect
lg ally remove primary shortcuts
lg ally removing short cuts
lg phone delete desktop shourtcut
remove shortcut lg ally
shortcut of alley
shortcut on desktop lg
uninstall shortcuts from lg android
