Ally will not turn on... hardware problem
This is a discussion on Ally will not turn on... hardware problem within the LG Ally Help forums, part of the LG Ally category; My Ally recently died. I've had it 3 months. It started acting weird a few days ago. Every time I slid the keyboard open or ...
Thread: Ally will not turn on... hardware problem
    Android Lurker Rachelface's Avatar
    My Ally recently died. I've had it 3 months. It started acting weird a few days ago. Every time I slid the keyboard open or closed it restarted. It also overcharged/overheated one morning. I think this is due to the fact that the power connection was faulty because of weak hardware. Only within a few days my phone won't turn on at all, there is no power connection whatsoever between the keyboard and the screen. I'm going to repair the phone hopefully, but now I have to be careful with how gentle I am with it, the hardware simply just isn't up to par.
    Other problems I've had with the Ally include the back button on the touch screen not responding for a day at at time. It's run very slow and frozen periodically, even using a task-killer. The email app is faulty and I have missed important emails depending on that app.
    I'm cheap so I'm sticking with the Ally but I wish I didn't have to deal with these problems.
    Can't say that I share any of your problems. I've dropped my Ally, slide it open and closed dozens of times every day, zero issues so far. It may be cheap initially but if you feel it's going to require a lot of repairs, it's not quite a bargain then.
    Android Jr Member amazinz5's Avatar
    charged mine to 100% last night, unplugged it, this morning it was frozen so i took the battery out and now it wont turn back on. i can wait a month or two for froyo but if this is gonna happen i might switch to the droid 2 or droid x.
how to fix a android ally that wont turn on
how to fix the andriod ally frezzing screen
lg ally died
lg ally died and wont turn back on
lg ally no power
lg ally not turning on
lg ally phone not turning on
lg ally phone will not turn on
lg ally screen not turning on
lg ally screen wont come on
lg ally screen wont turn on
lg ally will not turn on
lg ally wont turn on
my lg ally wont turn on
why isnt my lg ally turning on
