Default Calendar
This is a discussion on Default Calendar within the LG Ally Help forums, part of the LG Ally category; I deleted the default calendar that was on my Verizon ALLY. It fit the top half of one home page perfectly. Can that be recovered ...
Thread: Default Calendar
    Android Lurker kkfroggie's Avatar
    I deleted the default calendar that was on my Verizon ALLY. It fit the top half of one home page perfectly. Can that be recovered or reinstalled?
    Greenville SC
    A couple of calendars come pre-installed as widgets on your phone, and you can't really delete them. If you killed the calendar accidentally, just go to the home screen on which you want the calendar, and touch the screen until an "Add to Home screen" window pops up. Select widgets, and try the calendars -- there's a an LG calendar and a corporate calendar, I believe -- and see which one suits you best.
    I hope you enjoy your phone.
    Thanks so much. It worked just as you said it would. I can see I have a LOT to learn about this smartphone. I like the LG Calendar (simple), and right now I think simple is what I need to start with!!
    Regards
andriod select default calendar
android calendar event privacy default
android default calendar
android default calendar lg
android default calendar problems
android lg calendar
android tablet default calendar
calendars default lg
default android calender
default calendar android
lg android calendar
lg android set default calendar
lg calendar failure
lg default calander
lg3 android calendar default
