Internal Memory Issues
This is a discussion on Internal Memory Issues within the LG Ally Help forums, part of the LG Ally category; I got my Ally maybe a month ago and have MAYBE 10 apps downloaded (not very large ones at that). Anyways, I keep having a ...
Thread: Internal Memory Issues
    Android Lurker JKov240's Avatar
    Anyways, I keep having a little icon pop up that the internal memory is low on space...I've read on clearing the cache of all the apps, and I did that, and even then it's still saying I have 14mb of space.
    HELP!
    And thanks in advance,
    Jon
    It is also saying "Text Message Memory Full" when all the threads are deleted...
    I ended up calling Verizon and doing a hard reset........fixed the issue, but apps, etc. were deleted.
    its not the amount of apps, its the size of the apps. Swype alone is over 10MB, Copilot Live takes up 17MB. it could fill up fast.
lg ally internal memory
lg ally internal memory full
lg ally internal memory full known issues
lg ally keeps saying memory full
lg ally memory full
lg ally memory issue
lg ally memory issues
lg ally memory problems
lg axis internal memory
lg axis low on space
lg axis low space
lg axis memory full
lg axis says low on space
lg axis text message memory full
my lg ally keeps saying my memory is full but it isnt
