erasing the settings
This is a discussion on erasing the settings within the LG Ally Help forums, part of the LG Ally category; Ok so I went into the manage apps setting on my phone and I was clearing caches on different programs thinking that will make my ...
Thread: erasing the settings
    Android Lurker tink087's Avatar
    Ok so I went into the manage apps setting on my phone and I was clearing caches on different programs thinking that will make my phone run better and I came to the settings icon and I guess I cleared that 2 and since I did that it wiped out my custom wallpaper and now I can't save any wallpapers 2 my phone factory or custom... h e l p!
    First, I would turn the phone off and then back on.
    Second, I would switch between Android Home and LG Home to see if that might reset it.
    After that I am not sure.
    Do you remember where the setting was?
    Perhaps who went to Settings>Privacy>Factory Data Reset? That would clear your phone and revert back to when you bought the phone.
    That would fix his problem but not cause it. I try not to suggest a factory reset too much since most users don't want to go through the effort to reset the phone.
tink087
