connect with pc
This is a discussion on connect with pc within the LG Ally Help forums, part of the LG Ally category; i have attempted to connect my ally with my pc. i've followed the instructions from the manual, however in my notifications/ window shade it doesn't ...
Results 1 to 10 of 18
Thread: connect with pc
    Android Lurker zsuzsanna19's Avatar
    i have attempted to connect my ally with my pc. i've followed the instructions from the manual, however in my notifications/ window shade it doesn't say anything. so i can't choose the usb connections. so, now what?!
    If there is no notification, then you are not connected. Try a different USB port or USB cord. Also try it on another computer.
    thank u i tried that, but still no luck. is it possible i have something turned off in my phone that shouldn't be? if so where would i look for that?
    There is no setting that I am aware of that will prevent the USB notification from showing.
    Android Lurker stephy_c's Avatar
    Ok I had the exact same problem. I called tech support and the guy I spoke with said that there is a setting that will prevent the usb notification from showing. He walked me through it and now the problem is fixed. He did say, however, that verizons database had no information whatsoever about this fix...he found it because he had the same prob with his phone. The fix is: from your home screen goto the settings menu, click on applications, click on development then make sure the box beside "usb debugging" in NOT checked. Then connect your usb cord to your computer and your problem should be fixed! It worked for me! Good luck and hope this helps!
    Yeah, I thought of that option too and I even tried it. On my phone, it does not matter if this option is checked or not, I still get the USB connected notification.
    Android Lurker beardedknight's Avatar
    Quote Originally Posted by stephy_c View Post
    stephy_c,
    Thank you so much for posting this fix! It worked for me and I am now connecting to my computer.
    Thanks again!!!!!
    Android Lurker adrian09's Avatar
    ok i am trying to tether with my ally using pdanet the computer is able to see my phone when the usb debugging is off but i need it on at the same time when i turn it on it disconnects me from the ally does any one now why this is happening im not sure if its the phone it self cuz i connected it to my wife laptop and it worked fine does any one have a clue or may be point me in the right direction
    ok i finnaly fix the problem with not being able to read my phone while in debugging mode if any one needs this info here it is on how to it very simple go to lgforum.com then click on drivers and support go down to verizon and click on the first link that says drivers and install it easy as that
    Android Lurker hbrrebel's Avatar
    Thank you, thank you, thank you. I have tried for two days to connect to my pc, now i can. Thank you, thank you, thank you.
connect lg ally computer
connect lg ally to computer
connect lg ally to pc
connecting lg ally to computer
how do i connect my lg ally to my computer
how to connect an lg ally to a computer
how to connect lg ally to computer
how to connect lg ally to pc
lg ally connect to computer
lg ally connect to pc
lg ally how to connect phone to computer
lg ally pc connect
lg ally usb debugging
lg ally usb debugging mode
my to fix problem to connect andriod phone to computer
