Camera flash will not work
This is a discussion on Camera flash will not work within the LG Ally Help forums, part of the LG Ally category; Ok I just got my phone yesterday and the flash worked for a little while, but now it won't work. I've messed with the flash ...
Results 1 to 8 of 8
Thread: Camera flash will not work
    Android Lurker patdchick23's Avatar
    Ok I just got my phone yesterday and the flash worked for a little while, but now it won't work. I've messed with the flash settings multiple times and it still won't work. Does anyone know if it is somewhere in my settings, maybe an app I downloaded is interfering, or a faulty camera?
    Have you tried to reboot the phone?
    I just did and it still will not work: (
    All of the settings for the camera are listed here: http://www.lgallyforums.com/topic/331-camera-settings/
    You can set your flash in settings but that is the only place I know of where you can do that. Might want to take it to Verizon and have them look at it.
    OK now the flash only works if it is pitch black. Is that normal?
    If you have it set to Auto, yes that would be normal. If you have it set to On, then it should flash every time.
    Yeah even when it is set to on it only flashes when pitch black.
    Android Lurker 2turbo2's Avatar
    Hey guys... I updated my lg ally and I dunno if that was the cause or a app I installed but my flash doesn't work anymore... has any1 heard of a fix for the lg ally flash. I uninstalled the flash light apps I had flashlight 2.7.9 I THINK lol don't quote me... I am running android 2.2.2 I rooted my phone before the update... I'm thinkin that had somthin to do with it
android camera flash not working
camera flash dont work
camera flash not working android
camera flash not working on my android phone
fix flash light lg g3
flash on camera not working
flash wont work stylo 2 plus
lg camera flash not working
lg g3 camera flash not working
lg g3 camera flash won't turn on
lg g3 flash not working
lg stylo camera flash not working
lg ultimate 2 flash not working
lgl41c phone flash diesnot work
why wount my flash to on my phone camerica
