Camera Help
This is a discussion on Camera Help within the LG Ally Help forums, part of the LG Ally category; Trying to take pictures, getting a "Capture Failed" message. Won't take picture with the SD card out (as it shouldn't) Tried with both the original ...
Thread: Camera Help
    Android Lurker chris48178's Avatar
    Tried with both the original 4gb SD card and a freshly formatted 16gb new card.
    I've taken picture before, not sure what's wrong now.
    Any ideas on where to start troubleshooting?
    -Chris
    That actually happened to me a few days ago. i just turned the phone off then turned it back on and the problem went away.
ally camera failed
android forum
capture fail lg ally
capture fail on ally
capture fail on an lg ally
capture failed android
how do you snap pictures on the ally
how do you take pictures on lg ally
lg ally camera capture fail
lg ally capture fail
lg ally taking picture failed
lg camera capture fail
lg takaing pictures failed message
my lg ally camera says capture fail
why does my phone keep saying taking picture failed
