Help, I think I bricked my phone ;_;
This is a discussion on Help, I think I bricked my phone ;_; within the LG Ally Help forums, part of the LG Ally category; Hello... Yesterday I rooted my LG Ally with Androot or whatever and installed a Velocity ROM... Now (only when plugged in though, if it's not ...
Thread: Help, I think I bricked my phone ;_;
    Android Lurker camn's Avatar
    Hello... Yesterday I rooted my LG Ally with Androot or whatever and installed a Velocity ROM... Now (only when plugged in though, if it's not plugged in it won't do anything) it just goes from just the LED light flashing red, to the LG logo, to the Droid logo (not the normal Android logo), to the Droid eye thing, to an error saying "The process com.android.phone has stopped unexpectedly. Please try again.", back to the Droid logo and finally to the Droid eye thing in a loop.. Is there a way to either get it working or reset it? I really need it working by tomorrow, I'm going to a concert and some friends wanted me to record it
    Apparently because I didn't wipe the cache, I would just reset with Clockworkmod since I made a backup of how it was before I installed the ROM but I can't really do anything on my phone, help ;_;
    Android Lurker kylehat68's Avatar
    with the phone turned off press call, menu and send. hold them down. that will get you back to the recovery screen.
    also, use the volume buttons to move up and down and the camera button to confirm what you want to do on the recovery screen.
    Quote Originally Posted by kylehat68 View Post
    Thank you, thank you, thank you!!!!! I owe you, man.
    no problem, i did the same thing to mine.
ally bricked
ally com.android.phone has stopped
bricked lg ally
bricked lg ally force close
completely bricked lg ally
how to restore a bricked lg ally
how to unsoft brick lg
how to unsoft brick lg ally
i bricked my lg ally help
i bricked my lg ally using...
i bricked my lg venice
lg ally bricked
lg vs660 force closure bricked need help
restor bricked ally with clockworkmod
z4root apk
