deleting ringtones
This is a discussion on deleting ringtones within the LG Ally Help forums, part of the LG Ally category; How do you delete ringtones you have downloaded?...
Thread: deleting ringtones
    Android Lurker nightowl_lgally's Avatar
    Quote Originally Posted by nightowl View Post
    figured it out by connecting usb to computer and deleting.
    "Astro File Manager" is a great file manager that installs on your Ally and lets you manipulate files as well... Plus it will backup your Apps!
delete ringtones lg connect
delete ringtones on lg ally
deleting ringtones from android
how do you delete ringtones on a lg ally
how do you delete ringtones on the lg connect
how to delete ringtone from ally lg
how to delete ringtones from an lg android phone
how to delete ringtones from android
how to delete ringtones from lg ally
how to delete ringtones fromandroid
how to delete ringtones off of lg ally
how to delete ringtones on lg ally
how to remove ringtones from lg ally
how to remove ringtones from lg m770
lg ally how to delete ringtones
