connection errors with email
This is a discussion on connection errors with email within the LG Ally Help forums, part of the LG Ally category; Since the update I am having trouble with my email accounts. I have 3 email accounts. My corporate one is working flawlessly, my roadrunner account ...
Thread: connection errors with email
    Android Lurker mapsatx's Avatar
    Since the update I am having trouble with my email accounts. I have 3 email accounts. My corporate one is working flawlessly, my roadrunner account has connection errors and my aol account just keeps reposting old emails. Help! How can I fix this?
    Android Lurker NightAngel's Avatar
    I too constantly have connection errors (looking at one again, sigh..)....I don't get it. Called Verizon and was told to remove battery and go into sEttings, Wireless and Network settings then into Mobile Networks. Once there, they had me
    1. Make sure Data Roaming was checked (yes)
    2.Network Mode should be Didgital Only Hybrid
    3.System Select should be Automatic
    4. ERI should be checked
    Ok, so then it worked for a couple of hours and then I got the dreaded Connection Errors AGAIN ! What should I do ???? I totally rely on getting email on the go and the email I use is Gmail, 2 different account names. Please help !
    Thanks !
    Peace !
    Quote Originally Posted by NightAngel View Post
    Thanks !
    Peace !
    I have been having the same problems with Gmail. Months ago, my gmail app that came with the phone, would have a constant connection error. No matter what I did it would not work. So I used my Email app, that I use for hotmail, to open gmail. That worked ok for a month but then started having issues as well. It would connect but it would do other weird things like I would have a new email so I open it and delete it but then when I open my gmail later the email I deleted would be back like I never opened or deleted it.this would keep happening. So I finally started using the original gmail again, and it was working. But now that is having issues again too. Its very disappointing. I really never know when I have a new email or I have to keep deleting the same ones over and over. Don't know what else I can do.
android connection error
android connection error e mail
android email connection error
android mail connection error
aol connection error android
aol connection error droid
aol connection error on droid
connection error android email
connection error aol email android
connection error email android
connection error on android email
connection error on android phone
droid connection error email
email connection error on android
there is a network connection error android
