Apps Running in the background
This is a discussion on Apps Running in the background within the LG Ally Help forums, part of the LG Ally category; I have been having a problem with Apps running in the background. I will notice my battery level going down and when I check the ...
Thread: Apps Running in the background
    Android Lurker svtflea's Avatar
    I have been having a problem with Apps running in the background. I will notice my battery level going down and when I check the app killer, the whole screen is filled with various apps that are running that I havent opened! Anyone else with this issue? What can I do?
    Please search the forum. This topic has been covered many of times.
android ally how to close apps
apps running in background on lg
how to close apps running in the back ground lg ally
lg ally apps running
lg ally running aops
lg genesis applications running in background
what back ground apps on lg
