LG ally and jawbone prime bluetooth help
This is a discussion on LG ally and jawbone prime bluetooth help within the LG Ally Help forums, part of the LG Ally category; Anyone else have the jawbone prime paired with their ally? Does voice dial work for you? It doesn't for me....
Thread: LG ally and jawbone prime bluetooth help
    Android Lurker mhauer4's Avatar
    Quote Originally Posted by C0D34RCH3R View Post
    I have not used the Prime, but I think there are still some Bluetooth issues with Android 2.1... I'll let you know if I hear of an update.
    Android Jr Member Darkhorse153's Avatar
    Last I heard Voice dialing over BT is not supported in Android 2.1 but is in 2.2 so you should'nt have to wait too long (we hope!)
    The Prime is a sweet headset though, I have one as well. I can live without the voice dial as long as it keeps the echoes, background noise, and static out.
    Did you try voice dialing with the phones built in software?
    Android Lurker blinky's Avatar
    Omaha, NE
    Yeah, the headset isn't the problem, it's 2.1. 2.2 fixes that issues though.
connecting jawbone to lg ally
help connect jawbone to lg ally
how to use bluetooth on an lg prime
how to use lg ally with bluetooth
jawbone and lg doesnt pair
jawbone bluetooth pairing to alle
jawbone connect with lg ally
jawbone lg
jawbone prime pairing lg
lg ally jawbone
lg ally/jawbone
lg bluetooth voice activation
pair jawbone with lg ally
pairing jawbone with verizon lg ally
sync jawbone bluetooth with verizon ally
