LG Ally Widget problem
This is a discussion on LG Ally Widget problem within the LG Ally Help forums, part of the LG Ally category; I have had the LG Ally for about 2 weeks now, I downloaded some battery app to help save my battery but it didn't work ...
Thread: LG Ally Widget problem
    Android Lurker Joe5888's Avatar
    Rochester, NY
    I have had the LG Ally for about 2 weeks now, I downloaded some battery app to help save my battery but it didn't work so I went to remove it yesterday. I did the settings, manage applications uninstall then went to the home screen and now where the widget used to be it has a gray box with white lettering saying problem loading widget and now it just stays there and I have no idea how to get rid of it. I have tried turning off the phone and turning it on, changing the theme then going back to the old one and even trying to put an app over it and it won't go away. Has anyone gotten this before or know how to remove it?
    thanks.
    -Joe
    Tap and hold on that dead widget and drag it down to the trash icon.
    Rochester, NY
    I have tried that, it won't move. If I tap on it then the phone vibrates and nothing happens. I think I might just take it to Verizon. Thanks for the reply though.
    Android Jr Member Venez68's Avatar
    Jersey Shore
    this has happened to me before as well, and i had no problems dragging it to the trash.
    that's the only way i know how to get rid of it.
    "STAY THIRSTY MY FRIENDS"
    Try reinstalling the app/widget. maybe it will come back then you can drag it to the trash, then uninstall it. In that order.
android forum
error loading widget lg p509
getting rid of widgets on lg
how do i remove widgets from my lg ally
how to get widgits on the ally android
lg ally problem loading widget
lg l70 problem loading widgets
lg phone problem loading widget
lg phone says problem loading widget
problem loading widget lg
problem loading widget lg p509
problem loading widget lg phoenix
problem loading widget on lg phone
problem loading widget on lg viper
problem loading widgets lgp509
