Stuck or froze???
This is a discussion on Stuck or froze??? within the LG Ally Help forums, part of the LG Ally category; sometimes my phone gets stuck or froze. has this happened to anyone else? is there something i should do? i have dr. web and system ...
Thread: Stuck or froze???
    Android Lurker sleepersubie's Avatar
    sometimes my phone gets stuck or froze. has this happened to anyone else? is there something i should do? i have dr. web and system task zone light. someone tell me if thats normal or if there is something i should do. thanks. im new to smartphones and all this so any help would be greatly appreciated.
    There is more going on here. Do you have a task killer? (System Task Zone sounds like it is a TK but I have never heard of it).
    My phone skips every once and a while but it usually responds within seconds. IDK what those Apps you wrote about are though. What else do you have installed?
    Android Jr Member tazman19's Avatar
    NJ
    Sometimes mine will get stuck and/or freeze but it resolves itself in about 5 seconds. Think of these android smart phones as mini computers. Usually happens when system resources are stretched.
android google site froze
