Getting "software not found" message for USB connection
This is a discussion on Getting "software not found" message for USB connection within the LG Ally Help forums, part of the LG Ally category; OK... I appear to be the only one with this problem. I am running windows XP and when I plugged my new LG Ally VS740 ...
Thread: Getting "software not found" message for USB connection
    Android Lurker ASBI65's Avatar
    OK... I appear to be the only one with this problem. I am running windows XP and when I plugged my new LG Ally VS740 into my computer I get a message : "software not found" and after I have the Wizard search for it... still nothing. Any Ideas? Thanks in advance.
android software not found
android software not found on my computer
android usb application not found
application not found usb to pc android
connect ally usb
connect lg ally usb
how to connect the lg ally to windows xp
lg ally connecting to a computer software
lg ally software for windows xp
lg ally software windows xp
lg ally usb mode
lg ally xp
lg android software for computer
usb software not found
