USB Issues
This is a discussion on USB Issues within the LG Ally Help forums, part of the LG Ally category; I been browsing and searching the manual and topics for awhile. I want to add music from my PC to my phone. I understand you ...
Thread: USB Issues
    Android Lurker Mazzie's Avatar
    I been browsing and searching the manual and topics for awhile. I want to add music from my PC to my phone. I understand you have to connect the USB. So I do so, next step is pull down the notifications bar and click the "USB Connection notification". Except I do not get any notification. The phone is charging from the PC but I don't know. My Computer says I need a CD which I know isn't true. I need a little help here.
    Android Lurker mortsdron's Avatar
    yep mr too same problem my computer does not recognize my new device. i am running with an old hp pavillionzd7000 running windows xp can anyone help with this problem? Thanks mortsdron
    You need to install the drivers needed for your pc to recognize the phone. There are a couple of threads that discuss this.
oc.mortsdron
