gps address deleting
This is a discussion on gps address deleting within the LG Ally Help forums, part of the LG Ally category; I have put addresses in my LG ally and now I can't delete them...
Thread: gps address deleting
    Android Lurker allgood's Avatar
    There is no way to delete addresses that are entered in the default navigation app that I am aware of. If you have upgraded the app, you can uninstall the upgrade and then reinstall it. I think that will clear all entered addresses.
    To clear the data from navigation, go to settings>manage applications>menu filter:all>maps....then choose clear data. It will wipe all previous entries, but leave the program intact.
    Quote Originally Posted by Ak8s View Post
    That was the first thing I checked. On my Ally, there is no data to clear yet I still have addresses showing up that I have used before.
    What version of maps are you using? I am still on 4309. I haven't updated because I keep reading people complaining about the updates. Maybe they removed the option to clear data in later releases. Because when I cleared it, it reset navi and emptied all previous searches.
    I am on Version 4665. I have not had any problems with the updated version of Google Maps.
    To the one that advised me on how to delete GPS addresses. Thank you.
clear address entries on maps app from android
delete places in gps on phone
do smart phones gps save addresses?
how can i delete addresses from my scout app for android
how do i delete addresses from my gps
how do i erase addresses in my gps
how do i remove addresses from gps on phone
how to delete a location in scout
how to delete address from gps
how to delete address on gps
how to delete address on scout
how to delete gps addresses
how to delete locations on droid gps
removing old gps addresses on android
with gps on phone can you delete previous addresses on it
