Micro SD Card
This is a discussion on Micro SD Card within the LG Ally Help forums, part of the LG Ally category; Argh! I am having trouble with the microsd card for my ally. I bought a 16gig microSD card for the phone. my ally keeps saying ...
Thread: Micro SD Card
    Android Lurker torchwoodabq's Avatar
    keeps saying that the card is damanged after i have spent the entire night syncing my music to it with windows media player or isync.
    the phone reads the card as 16gig if i format the card with a card reader on my laptop but wont let me use the card on the phone.
    Does the Ally have a gig limitation on it or is it just the card. I have a sandisk 16gig card.
    if i cant use this on the phone oh well i can stick into my sansa mp3 player.
    thanks
    How did you sync your music? Did you put them on your SD Card with the computer then put the card into the phone? Instead, put the card in the phone, format the card with the phone then transfer your files using the USB Cord.
    Officially, the suggested limit is 16 MB but 32 MB is reported to have worked.
android 4.4 cant reformat damaged micro sd
android microsd card format keeps being damaged
android reformat micro sd card
best micro sd card for lg ally
free drivers for lg android phone to format sd card
how to format mini sd card on lg ally android phone
how to reformat micro sd card using a lg ally
isync to sd card in android
lg alley keeps saying damaged sd card
lg ally wont read my sd card?
lg android/sd sync
my micro sd card keeps saying damaged
reformat micro sd card for lg ally
sd formatter free download
why does my media player keep saying my sd card is damaged
