dumb question on volume
This is a discussion on dumb question on volume within the LG Ally Help forums, part of the LG Ally category; Hi, How do you adjust the call volume on the Ally? Is it the rocker switch on the left side? I know that controls ring ...
Thread: dumb question on volume
    Android Lurker hockeyboy09's Avatar
    Hi,
    How do you adjust the call volume on the Ally? Is it the rocker switch on the left side? I know that controls ring tone. Can you adjust call volume independent of the ring volume?
    I haven't learned how to set the speaker phone to on yet either. Thanks!
    The volume rocker will control the in call volume when you are on the phone. To turn on speaker phone when in a call, just tape the bottom right square on the screen that says 'speaker.' It will turn on a little orange line underneath it to know that it is activated.
    Thanks, My Ally is so new that I haven't received a phone call yet to see the speaker icon.
    The volume rocker adjusts whatever you happen to be doing at the time. if you are in a call it adjusts the call volume. if you are listening to music it adjusts the music volume. if you are using Navigation it adjusts that, etc. There are also apps that let you adjust all the volumes manually in one spot. I use the miniinfo widget for that.
    ... and if you are using a reader like Aldiko it can turn the page of the book you are reading.
adjust volume on lg phone
adjusting headphone volume one android phone
android forum
android lg ally navagation volume
google nexus how to adjust volume phone android 4.1
how do i adjust call volume on lg phone
how do i turn on speaker on lg ally
how to adjust call volume on the lg
how to adjust incoming call volume on lg ally phone
how to adjust volume on lg phone
how to change speakers volume on lg ally phone
how to change volume on lg phone
how to set call volume on lg phone
lg ally in call volume
lg phone in call volume
