How to Remove Redial Feature
This is a discussion on How to Remove Redial Feature within the LG Ally Help forums, part of the LG Ally category; Hello All My Ally-Helpers: Am I the only Ally user getting in trouble or looking like an idiot because I keep redialing a person after ...
Thread: How to Remove Redial Feature
    Android Lurker Alfistigirl's Avatar
    Hello All My Ally-Helpers: Am I the only Ally user getting in trouble or looking like an idiot because I keep redialing a person after a call? Even my daughter doesn't answer my repeat calls because she thinks I redialed her. I searched and searched using the keyword "redial" and no topics are out there. This function occurs after slighly pressing the exposed left bottom corner of my phone. Is there any way to remove it?
    There's a redial feature?
    The left button is the call button but you would have to have your phone unlocked and hit that button twice to have it redial the last number dialed on the phone. Simply lock the phone and you don't have to worry about it.
disable two click redial android
galaxy s4 keeps redialing last number
how to delete redial
how to delete redial on home phone
how to delete redial on housephone
how to disable redial last number
how to get rid of redial on phone
how to remove redial
how to remove redial from an android phone
how to remove the 1 during redial
lg 240g keeps redialing phone numbers
ls670 lg phone how to disable last number redial
removing redial feature
removing redial search
z4root apk
