Very loud noise when turning Ally on.
This is a discussion on Very loud noise when turning Ally on. within the LG Ally Help forums, part of the LG Ally category; When ever I turn my lg ally on it makes a very loud noise. Even if I have it on silent or vibrate. On my ...
Results 1 to 8 of 8
Thread: Very loud noise when turning Ally on.
    Android Lurker Kt5's Avatar
    When ever I turn my lg ally on it makes a very loud noise. Even if I have it on silent or vibrate. On my old phone the lg voyager when the phone was on vibrate, it vibrated when iturned it on.
    Is there any way to change the settings on the ally so it doesn't make that loud of a noise
    Is the "noise" you are referring to the Verizon startup music or an actual noise like a beep or clanging?
    You should do a search because this has been covered in the forum already.
    Alas, short answer is you can't change the startup jingle unless you root your phone and install a custom ROM.
    Actually the startup tone will obey the system sound at time of shutdown. If you have the sound off when you turn off the phone then the sound will be off when you boot up and you will NOT hear the tone.
    Wow...I didn't realize that. Seems like it wasn't always that way but I could be wrong there too. Thanks for the tip!
    It was that way. It got fixed in VB.
    @u
    @marioval that doesn't work I tried it
android makes noises when turning on
droid makes loud noise when turning on
how to change lg ally system sounds
how to change turn on/off sound for lg ally
how to turn off startup sound on lg ally
lg ally how to disable startup sound
lg loud noise when turning on
lg phone loud noise
loud beep on lg ally
loud noise with lg tone
loud sound when turning on your phone
my android is loud when turning on
on ally phone can you turn off sound of phone turning on
replace system sounds on lg ally
turn off startup sound lg ally
