Auto-correct spelling
This is a discussion on Auto-correct spelling within the LG Ally Help forums, part of the LG Ally category; Is there any way to get the Device Keyboard (the built-in keyboard) to auto-correct spelling? I've gone to the Keyboard Settings and turned on Auto-replace ...
Thread: Auto-correct spelling
    Android Lurker dadamsfwsymphony@gmail.com's Avatar
    Is there any way to get the Device Keyboard (the built-in keyboard) to auto-correct spelling? I've gone to the Keyboard Settings and turned on Auto-replace which should "correct mistyped words" but it doesn't seem to do anything. What exactly is Auto-replace supposed to do? The "quick fixes" and "show suggestions" for the Android keyboard (the onscreen touch keyboard) work as they are supposed to.
    Thanks in advance for any help or suggestions.
    Quote Originally Posted by dadams View Post
    Setting>Language and Keyboard>Android Keyboard>Quick fixes Make sure it has a green check.
    Sorry...misread your question. Auto replace doesn't fix the spelling. It will type in the word tha tis highlighted orange in the word suggestions if you hit the space bar so you don't have to finish typing the word.
    Android Lurker holland3346's Avatar
    All of my options in the setting you suggested are checked green but I've never had it suggest another word or anything? I got very used to the auto fill type stuff that was on my blackberry (it recognized things the more often I typed them) & I really miss it with the Ally.
android auto spelling
android keyboard auto correct
android lg model 39c turn off auto correct
how to turn off autocorrect on lg intuition
how to turn off autocorrect on lg spectrum
how to turn off autocorrect on lg spectrum 2
how to turn off spell check on lg spectrum
htc dna droid how to check for misspelled words but not autocorrect?
lg g3 spell check auto correct
lg spectrum 2 auto correct
lg spectrum 2 autocorrect
lg spectrum 2 turn off autocorrect
lg spectrum autocorrect
lg spectrum turn off autocorrect
spectrum auto correct
