Wifi Login Page
This is a discussion on Wifi Login Page within the LG Ally Help forums, part of the LG Ally category; Hi all. At my company we have a network for contractors to log into that does not go through our proxy servers. The network is ...
Thread: Wifi Login Page
    Android Lurker Dize815's Avatar
    Hi all. At my company we have a network for contractors to log into that does not go through our proxy servers. The network is unsecured but it does require an HTML login and the passord and username change every month. I can connect to the network with no problems but when I open my browser I get an error when it opens the https://1.1.1.1/login.html page. It tells me the web page is not available. I can connect to the same network on my ipod touch so I know it can work. Any suggestions on what to try or what I might be doing wrong?
    Thanks,
    Dize
    I use a program called WiFinder to find and login to my WiFi but I don't have to login with an HTML page.
1.1.1.1. login.html
android phone will not open wifi login page
android popup wifi login
android public wifi pop up
android wifi connection popup
android wifi login page
android wifi popup login page
android wifi web login does not pop up
android wifi web login pop up does not show up
htc wifi login page
https 1.1.1.1 login.html android
https://1.1.1.1/login.html fail
lg ally web page not available
lg wifi login
wifi login page on android
