Help with my SD card and Pics
This is a discussion on Help with my SD card and Pics within the LG Ally Help forums, part of the LG Ally category; I took my sd card out of my ally so my friend could put her pics on my card..when I put my card back in, ...
Thread: Help with my SD card and Pics
    Android Lurker LEANNAW's Avatar
    I took my sd card out of my ally so my friend could put her pics on my card..when I put my card back in, none of my pics or music were on it? All I have now is her pics...Can you tell me where my pics and music went? Did I lose them? Thanks!!
    Quote Originally Posted by LEANNAW View Post
    Did you "Dismount" your MicroSD card before removing it? If you didn't the file structure might have been damaged so your files were lost... There are some File recovery utilities out on the web that you might try... But since you have written new files to the MicroSD card, you might not be able to get any of your photos back... You might try "zero assumption recovery" from the Cnet site to see what it will do.... But this is kind of advanced stuff so I'm not sure if you want to try it...
    Good Luck.
damaged sd card android ally
damaged sd card lg ally
damged sc card on ally
did not dismount sd card and lost files
dismount sd card android
do i need to dismount my android micro sd card?
how do i check the pictures on the sd card on my ally
how to pull pics from a damaged sd card in android
how to tell if pictures loaded on sd card visialand android
lg ally damaged sd card
lg ally sd card damaged
lg ally sd card to tame pics?
lg android put new photos on sd card
lost pictures that i down loaded on lg ally
will i lose files if i dismount sd card
