Mysterious Arrow Symbols / Icons
This is a discussion on Mysterious Arrow Symbols / Icons within the LG Ally Help forums, part of the LG Ally category; My LG Ally phone has two symbols on top left corner I can't figure out what they mean. both have an arrow pointing down and ...
Thread: Mysterious Arrow Symbols / Icons
    Android Lurker MardiDavis's Avatar
    My LG Ally phone has two symbols on top left corner I can't figure out what they mean. both have an arrow pointing down and a straight black line below the arrow. Used to just have one and now another appeared. Can't find any similar icons in the manual.
    If it is the one I am thinking of, it means you had a missed call.
    Are you referring to downloading and uploading?
    Look, just swipe the notification bar down and it will tell you what it is. LOL
    Quote Originally Posted by Jeannie View Post
    They are Icons indicating that you have downloaded a file... In your case two files.... Open the Notification bar and click on "Clear All" and they will disappear.... Or in the Notification window, look at each one and it will tell you what file was downloaded, then you can clear them with the "Clear All" button.
circle arrows on lg vigor
i have two arrows at top of my phone one pointed up and one pointed down in a square(net 10 phone
moto g4 has a notification download arrow in top left of screen . how do i get rid of it?
my tmobile phone shows an arrow to the left of signal bars and a grid to the right
radar symbol with arrows on a lg6
what an arrow down witj a line under on my phone
what do all the arrows pointing down on the top of my phone mean
what does a bent arrow on my phone mean
what does flashing blue arrow virgin broadband hub 2 mean
what does the little arrow mean on my kindle
what does the up and down arrows mean on wifi and how do you use it
what is circle aroow pointing down mean?
what is the 4arrows in the lower right hand corner of the screen of the kindle fire
what is the horizontal bar with a down arrow in the upper left corner of my phone screen samsung
why would my straightalk lgl15 g have a small cloud icon in the upper left corner
