Battery Question
This is a discussion on Battery Question within the LG Ally Help forums, part of the LG Ally category; Here's a new one. I haven't seen it mentioned before. Yesterday we had to take a trip to northern Delaware. I used the awesome navigation ...
Thread: Battery Question
    Android Lurker jal7884's Avatar
    Selbyville,de
    Here's a new one.
    I haven't seen it mentioned before. Yesterday we had to take a trip to northern Delaware. I used the awesome navigation app. I plugged the phone into the car charger to conserve the battery. About half way to our destination I notice the battery icon has a question mark and it is showing that the battery is drained. Go to settings and it says battery is a zero and not charging. I unplug the charger and i have 88% and status is discharging. plug the charger in and again it shows the question mark and zero charge status. I left it unplugged till we reach our destination. I turned off the nav app and plugged it in and every thing was normal. On the way home it did the same thing. Has anyone had this happen or know if it is normal? thought it may have been an overheating issue.
    Thanks
    Jeff
    Same thing has happened to me a few times. I'm not sure what it is? Rebooting the phone is what I did to get rid of the question mark on the battery. Maybe someone else can shed some light on this.
    I always thought that symbol meant there was an issue with the charging of the battery. Usually for me, I just need to unplug it for a few minutes and it goes away.
android phone shows question mark on battery sign
android question mark battery
android question mark on battery icon
battery sign on android
droid 3 battery question mark
droid razr not charging battery question icon
lg ally battery question mark
lg ally insert your battery
lg battery question mark
lg phone battery question mark
lg thrive shows a question mark for the batter
lg volt phone battery question mark
motorola razr battery symbol with question mark
question mark in battery icon droid
question mark on battery icon android
