BATTERY OVERHEATING
This is a discussion on BATTERY OVERHEATING within the LG Ally Help forums, part of the LG Ally category; I'VE HAD MY ALLY ABOUT A MONTH AND STARTED GETTING THESE WARNINGS TO SHUT DOWN THE BATTERY TO COOL OFF. AT FIRST I THOUGHT IT ...
Thread: BATTERY OVERHEATING
    Android Lurker SALBERG27's Avatar
    I'VE HAD MY ALLY ABOUT A MONTH AND STARTED GETTING THESE WARNINGS TO SHUT DOWN THE BATTERY TO COOL OFF. AT FIRST I THOUGHT IT COULD BE AN APP I HAD BUT AFTER UNINSTALLING IT IT CONTINUED TO HAPPEN TODAY. I INSTALLED A BATTERY LIFE WIDGET AND IT SAYS MY BATTERY IS 114.8. IT'S SHUT DOWN ON ITS OWN WHEN EVEN HIGHER. I BOUGHT MY PHONE ON EBAY AND IT WASN'T CHEAP EITHER. I DID GET AN EXTENDED WARRANTY TOO. NOT SURE WHAT TO DO. I'M NOT A VERIZON CUSTOMER ANYMORE SO CAN'T CALL THEM EITHER. ANY IDEAS?
    Android Jr Member vortmax's Avatar
    You say you have an extended warranty, so I would contact the seller. To me it sounds like an issue with the internal circuitry of the battery, but it could also be something with the phone.
android battery overheating
battery over heating lg motion
battery overheating android
cooling down over heated phone battery
fix overheated battery for lg m480
lg ally battery overheating warning
lg ally battery overheats
lg ally overheating
lg battery overheating
lg marquee says battery overheating but battery is new
lg motion overheating
lg overheating warning
lg phone battery overheating
verizon tablet overheating
why is my lg motion over heating
