I would like to reset my phone. I have a general idea how to do this but what does it exactly do? Delete phoonbook pics music all apps any info would be great thanks
This is a discussion on help with a factory reset please within the LG Ally Help forums, part of the LG Ally category; I would like to reset my phone. I have a general idea how to do this but what does it exactly do? Delete phoonbook pics ...
It will reset your phone to "out of box." It will remove all apps and info and restore to factory settings. Your contacts are safe if you have synced them with Gmail. If not, you should do that first. Then backup Apps you want. Your reset will not effect the SD Card. You'll be prompted to "touch the Android to begin" just like the first time.
Thank you, will I have to call up verizon and reprogram the phone
No, you can reprogram it yourself by dialing *228 and Option 1.
What happen to all my apps that I paid for? Is it still there in the Market Place?
Don't be cheap. Just rebuy them! haha, j/k Your purchases are tied to your google email and should be there to redownload for free.![]()
