Help with City ID and Advanced Task Killer?
This is a discussion on Help with City ID and Advanced Task Killer? within the LG Ally Help forums, part of the LG Ally category; I was on Advanced Task Killer and I saw City ID and I accidentally made it so that I can't see when its running. Now ...
Thread: Help with City ID and Advanced Task Killer?
    Android Lurker nia582's Avatar
    Now because of that, my memory is decreasing horribly.
    How can I make it visible on Advanced Task Killer again?
    Thank you.
    1. Open the ATK app.
    2. Press the menu button.
    3. Touch Settings.
    4. Touch Ignore List.
    5. Touch City ID.
cannot remove city id from lg ally
how can i remove city id from lg ally
