Recovery Mode
This is a discussion on Recovery Mode within the LG Ally Help forums, part of the LG Ally category; How do I boot into recovery? I see that everyone says power and X at the same time, but that doesnt work for my Ally....
Thread: Recovery Mode
    Android Lurker suntech's Avatar
  2. is the premier Android Forum. Registered users do not see these ads. .
    Do you mean safe mode?
    1. Power the LG Ally off.
    2. Slide the keyboard open.
    3. Press and hold the OK key while powering the device back on.
    4. Keep holding the OK key until you see the Home screen load. It should say Safe Mode in the bottom-left corner of the screen.
    To take the device out of Safe Mode, simply turn the device off, then back on.
    OR Do you mean Factory Reset?
    1. From the Home screen, press the Menu key .
    2. Touch Settings > Privacy > Factory data reset.
    3. Read the warning and touch Reset phone.
    Or, when the phone is off hold Volume, Home and Power for a few seconds.
    If a factory reset is performed, all installed application and user data will be erased. Please remember to back up any important data before performing a factory reset (from manual).
    Android Lurker PSpaceman1's Avatar
    If you want to boot into recovery, shut the phone down till its completely off. Then hold call, menu, and the call end soft key buttons on the bottom of the phone at the same time, below the touch screen. until you see the LG logo pop up. Hold onto the three buttons until you see a tiny Android insignia, it will be tiny green print. It will then send you into recovery. From there, you can load .zip files, delete caches, etc.
gplgl15gb hard reset
how to get my lg airsto into stock mode
, enter boot lg premier
lg android recovery
lg gplgl15gb
lg phone recovery mode
lg phone recovery tool
lg recovery mode
lg sunrise recovery
lg sunrise recovery mode
lgms323 safe mode
recovery mode for lg phones
recovery mode lg phone
recovery mode on lg premier
