Low on Storage?
This is a discussion on Low on Storage? within the LG Ally Help forums, part of the LG Ally category; I have 3.69gb total space, avail space is 3.47gb on SD card and keep getting low storage messages. I don't know why this keeps happening. ...
Thread: Low on Storage?
    Android Lurker coltow's Avatar
    I have 3.69gb total space, avail space is 3.47gb on SD card and keep getting low storage messages. I don't know why this keeps happening. Anyone?
    Quote Originally Posted by coltow View Post
    Probably getting the low storage message because your internal storage is near full capacity. The Ally is not exactly a large internal storage device.
    Quote Originally Posted by glockman39 View Post
    How can I fix/clean that
    You either have too many apps, or your cache sizes are too large.
    Try this first.... go to menu>settings>applications>manage applications>menu>filter>all>menu>sort by size Then...check each app and clear the cache on them. Also, if you are using the email app, you need to delete all the *trash*. Clear your call logs and delete any old texts you don't need. If you do this, and you STILL get the low memory warnings, then you probably have too many apps installed.
    Quote Originally Posted by Ak8s View Post
    THANK YOU it has to be my email. I have almost 1000 messages in the "trash"
    I use an app called Quick App Clean cache. It allows me to clean out all caches.
android low on storage
android low storage
how many gb does an lg ally have
how many gb does lg ally have
how many gb does the lg ally have
how much memory does the lg ally have
lg ally insufficient storage
lg ally low memory fix
lg ally memory capacity
lg ally memory fix
lg axis low memory
lg axis low storage
lg axis low storage space error
low storage android
total space(external) 3.69gb
