Remove System Updates
This is a discussion on Remove System Updates within the LG Ally Help forums, part of the LG Ally category; Is there anyway to remove system updates? The last system update corrupted on me while it was downloading and now it just says my system ...
Thread: Remove System Updates
    Android Lurker Jonotjohn's Avatar
    Is there anyway to remove system updates? The last system update corrupted on me while it was downloading and now it just says my system is up to date. Ive been looking it up for awhile now and decided to do a factory reset, but then realized, apparently, it doesnt affect the system updates at all. It just removes all the data from the phone. I'm just trying to find a way to fully update my phone again. Correctly this time. Thanks for any help.
    Android Jr Member vortmax's Avatar
    If the phone isn't rooted, I would call Verizon and have them sort it out. If it is rooted (and you can't bring it back to stock), or you want to try and fix it yourself, take a look here:
    http://savoxis.com/ally/recovery.html
    That site has the stock ROM in the download section. You should be able to reflash it and bring the phone back to VZ8 then update to VZC.
android delete system update
how to remove android update
how to uninstall an update on android
how to uninstall android update
how to uninstall android updates
how to uninstall system update
how to uninstall system updates on android
how to uninstall updates on android phone
remove android system update
uninstall android 6.0 update
uninstall android system update
uninstalling android update
unistal my new update android mobile
