Problems viewing text messages
This is a discussion on Problems viewing text messages within the LG Ally Help forums, part of the LG Ally category; I installed the app "Quick Settings" and turned off the 3G to save on racking up data charges. I use Wifi when it is available. ...
Thread: Problems viewing text messages
    Android Lurker kbriggs77@yahoo.com's Avatar
    I use Wifi when it is available. I am getting an error message all of the sudden when trying to view text and pic messages.
    I turned the 3G back on and the message downloaded just fine. Why?
    Is there a way to just use Wifi for viewing these? Do I need another app like Adobe or something?
    Banned JohnCena83's Avatar
    You can turn 3G off in settings, but it should default to wifi when it is availabe. mine does.
    Quote Originally Posted by John Cena View Post
    It does. I only have problems downloading an incoming media message when using Wifi instead of 3G.
    If I turn the 3G back on and try to download it......it works fine.
android issue viewing text messages
having trouble viewing a text message on android
lg android phone trouble viewing multimedia messages
trouble viewing text message
