SD CARD HELP
This is a discussion on SD CARD HELP within the LG Ally Help forums, part of the LG Ally category; Hey Guys, If I get a larger SD Card can I just copy and paste all the information to the larger SD Card? Also will ...
Thread: SD CARD HELP
    Android Lurker xx8trick8xx's Avatar
    Hey Guys,
    If I get a larger SD Card can I just copy and paste all the information to the larger SD Card? Also will this help with the message saying Low space?
    You will need to format the card first. Make sure it is formated in the phone.
    And the SD card has nothing to do with the low space message.
    Both formatting SD Cards and dealing with low memory issues are covered in the forum. A quick search can find info on both.
