why in Gods name does my clock keep flashing
This is a discussion on why in Gods name does my clock keep flashing within the LG Ally Help forums, part of the LG Ally category; Every time its plugged in regardless if its sitting idle or if I'm messin with my phone the clock screen will flash. If I'm on ...
Thread: why in Gods name does my clock keep flashing
    Android Lurker dpacski's Avatar
    Every time its plugged in regardless if its sitting idle or if I'm messin with my phone the clock screen will flash. If I'm on utube it kills the vid if I'm looking for apps it kills the app anyone have a clue ????
    There have been a couple of threads about this but so far no one has found an answer.
    I would try a reboot and if it continues after that do a factory reset.
    Well I did a factory reset plugged in the phone not 10 seconds later clock screen flashed so I went back to the clock app and deleted all open alarms badabing it worked
    You still had alarms set after a factory reset? Those should have been erased.
    No I did the reset late at night to tired to screw with the phone had to get up early so I set a couple alarms next day when I finally got to the phone is when I deleted the alarms no problems since
alarm clock keeps blinking
alarm clock keeps flashing
blinking digital clocks
digital alarm clock keeps blinking
digital car clock keeps flashing
digital clock keeps flashing
how to keep the clock from flashing on my droid max
why clock flashing numbers mhz
why does my alarm clock keep blinking
why does my alarm clock keep flashing
why does my atomic clock keep blinking on alarm?
why is my alarm clock blinking
why is my alarm clock flashing
why is my clock blinking
