What changes? SD card.
This is a discussion on What changes? SD card. within the LG Ally Help forums, part of the LG Ally category; I dropped my phone and shattered the screen...sooooooooo..... my new one comes tomorrow. My question is what is on the SD card? I know apps ...
Thread: What changes? SD card.
    Android Lurker Tricia_Anne's Avatar
    I dropped my phone and shattered the screen...sooooooooo..... my new one comes tomorrow. My question is what is on the SD card? I know apps will have to be re-downloaded (and I worked so hard on angry birds), but what else? All pictures, just ones taken by the phone, downloads, ringtones....ect. I am so lost on what is saved on the SD card.
    TIA,
    Trish
    Android Jr Member RedDroid_lgally's Avatar
    Phoenix, AZ
    Trish,
    The SD card in my Ally has my pictures, mp3 files, videos, ringtones I created, plus there are folders of data created by the phone and some created by the applications. I can't say if your Angry Birds progress is saved, but there is quite a bit of interesting stuff on there.
    Saved Games are not typically stored on the SD Card. If an App put something there it is data or cache. The cache is typically icon thumbnails so when you open the App you see the right icons quickly. These are not important. Most Apps will regenerate missing folders, or if not just uninstall and re-install the App. Some Apps store data on the SD Card, like if the game is huge (Super KnockOut Boxing), or like the off-line dictionary I use that stores the words on the SD Card (Color Dictionary). These Apps will ask your permission beforehand. The data is Pictures, Music, Ringtones, or Notes you may have added using a Note App... Anything you put on there yourself or used an App to "Save to SD Card". This is part of why I put all the stuff I added in a folder called "Media." This is also why I am taking advantage of Google's Picasa free photo storage. All your pictures or movies made with the phone are in the folder called DCIM (Digital Camera Images). Your camera will not work without an SD Card.
    Also check out the download folder. That folder is generated by Apps like the Browser, Gmail, or Messaging. Some Apps make the folder "Downloads" instead of "Download."
    I resently did a factory reset on my phone because it was acting "stupid." I also copied my entire SD card and moved it to my computer. I then reformated my SD card. After reinstalling all my apps, I moved just a few photos over from the PC to the new card. It looks much cleaner. After going on a app orgy when I first got my phone, there were many orphaned folders on my SD card from long since deleted apps.The contents are much easier to look through and after the reset, the phone runs much smoother.
    Banned Karlito2007's Avatar
    Pasaporte falso COMPRA FRANCES, CANADA PASAPORTES FALSOS EN VENTA, BRITANICA DE LINEA
    Nuestro equipo es un productor unico de la calidad de documentos falsos.
    Ofrecemos solo originales pasaportes falsos de alta calidad, licencias de conducir, tarjetas de identificacion, sellos y otros productos para una serie de paises como:
    Estados Unidos, Australia, Belgica, Brazil, Canada, Italia, Finlandia, Francia, Alemania, Israel, Mexico, Paises Bajos, Sudafrica, Espana, Reino Unido. Esta lista no es completa.
    Para obtener la informacion adicional y realizar el pedido solo hay que visitar nuestra pagina web:
    www. fakepassportsale.cc http://www.fakepassportsale.cc
    >> Contact e-mails:
    General support: support@fakepassportsale.cc
    Technical support: tech@fakepassportsale.cc
    Palabras clave:
    comprar Argentina pasaportes falsos de conduccion tarjeta de Identificacion de licencia para la venta en linea
    comprar australiano pasaportes falsos de conduccion tarjeta de identificacion de licencia para la venta en linea
    comprar comprar Austria pasaportes falsos de conducir licencia de tarjeta de identificacion para la venta en linea
    comprar pasaportes falsos de conducir belga tarjeta de Identificacion de licencia para la venta en linea
    comprar brasilena pasaportes falsos de conduccion tarjeta de Identificacion de licencia para la venta en linea
    comprar pasaportes falsos de conduccion bulgaros tarjeta de Identificacion de licencia para la venta en linea
    comprar pasaportes falsos de Canada de conduccion tarjeta de Identificacion de licencia para la venta en linea
    comprar chino pasaportes falsos de conduccion tarjeta de Identificacion de licencia para la venta en linea
    comprar cubana pasaportes falsos de conduccion tarjeta de Identificacion de licencia para la venta en linea
    comprar chipriota pasaportes falsos de conduccion tarjeta de Identificacion de licencia para la venta en linea
    Checa comprar pasaportes falsos de conduccion tarjeta de Identificacion de licencia para la venta en linea
    comprar danesa pasaportes falsos de conduccion tarjeta de Identificacion de licencia para la venta en linea
    Republica Dominicana comprar pasaportes falsos de conducir licencia de tarjeta de identificacion para la venta en linea
    comprar ecuatoriana pasaportes falsos de conduccion tarjeta de Identificacion de licencia para la venta en linea
    comprar Estonia pasaportes falsos de conduccion tarjeta de Identificacion de licencia para la venta en linea
    comprar finlandes pasaportes falsos de conduccion tarjeta de Identificacion de licencia para la venta en linea
    comprar frances pasaportes falsos de conduccion tarjeta de Identificacion de licencia para la venta en linea
    comprar pasaportes falsos de conducir aleman tarjeta de Identificacion de licencia para la venta en linea
    comprar griega pasaportes falsos de conduccion tarjeta de Identificacion de licencia para la venta en linea
    comprar hungaro pasaportes falsos de conduccion tarjeta de Identificacion de licencia para la venta en linea
    comprar Islandia pasaportes falsos de conduccion tarjeta de Identificacion de licencia para la venta en linea
    comprar indios pasaportes falsos de conduccion tarjeta de Identificacion de licencia para la venta en linea
    Indonesia comprar pasaportes falsos de conduccion tarjeta de Identificacion de licencia para la venta en linea
    comprar irlandesa pasaportes falsos de conduccion tarjeta de Identificacion de licencia para la venta en linea
    comprar pasaportes falsos de conducir de Israel tarjeta de Identificacion de licencia para la venta en linea
    comprar pasaportes falsos de conducir italiano tarjeta de Identificacion de licencia para la venta en linea
    japoneses compran pasaportes falsos de conduccion tarjeta de Identificacion de licencia para la venta en linea
    Corea comprar pasaportes falsos de conduccion tarjeta de Identificacion de licencia para la venta en linea
    comprar Letonia pasaportes falsos de conduccion tarjeta de Identificacion de licencia para la venta en linea
    comprar Lituania pasaportes falsos de conduccion tarjeta de Identificacion de licencia para la venta en linea
    comprar luxemburgues pasaportes falsos de conduccion tarjeta de Identificacion de licencia para la venta en linea
    Malasia comprar pasaportes falsos de conduccion tarjeta de Identificacion de licencia para la venta en linea
    comprar pasaportes falsos de conducir mexicana tarjeta de Identificacion de licencia para la venta en linea
    comprar monegasca pasaportes falsos de conduccion tarjeta de Identificacion de licencia para la venta en linea
    comprar holandes pasaportes falsos de conduccion tarjeta de Identificacion de licencia para la venta en linea
    Canada pasaporte falso, id novedad plantillas, la novedad tarjetas de identidad, licencia de conducir de plantillas, las tarjetas de la novedad de identidad, tarjeta de identificacion de la prueba, tarjeta de identificacion de Michigan, como hacer tarjetas de identidad, robo de identidad pasaporte, licencia de conducir hologramas, como obtener un pasaporte de Canada, Identificacion phatism, carne de estudiante falsos, Identificacion de licencias de conducir, tarjeta de identificacion nueva Hampshire, hacer una tarjeta de identificacion, la novedad tarjeta de identificacion, licencia de conductores de plantilla, hacer una tarjeta de identificacion, licencia de conducir Identificacion, holograma licencia de conducir, tarjeta de Identificacion de edad, la novedad plantilla de Identificacion, plantilla de identificacion con foto, pasaporte Canada formas para imprimir, elegir n salvar solicitud de empleo, la novedad Canada tarjetas de identificacion, prueba de Identificacion del publico, la novedad Identificacion de California, como obtener una tarjeta de identificacion, como obtener una tarjeta de identificacion, identificacion con foto plantillas, tarjeta de identificacion de edad , la prueba de falsa identificacion de edad, identificacion falsa autenticos, fluxcard Identificacion, Identificacion de plantillas para su descarga gratuita, la plantilla de identidad, pasaporte robo de identidad, libre de la plantilla licencia de conducir, identificacion con foto permiso de conducir, pasaporte licencia de conducir, tarjetas de Identificacion phatism, llenar la solicitud de pasaporte, prueba de las tarjetas de identidad edad, licencia de conducir de plantillas, los hologramas de identificaciones, tarjetas de Identificacion novedad, la prueba de las tarjetas de identidad, licencia de conducir holograma, hacer una linea de pasaporte, licencia de conducir plantilla Trabajo Old Navy formulario de solicitud en linea, la necesidad de identidad falso, plantillas para tarjetas de identificacion, los secretos de un hombre callejon Identificacion, prueba de la tarjeta de Identificacion, Identificacion falsa con holograma pase, la marina en linea de solicitud de empleo de edad, descarga gratuita Identificacion tarjeta de plantilla, sin hacer Identificacion, como hacer la tarjeta de identidad, id escaneable novedad, la renovacion de pasaportes canadienses en linea, plantillas de fotos gratis Identificacion, formas renovacion de pasaporte canadiense Identificacion en linea, descargar plantillas, tarjetas creadas theidshop, como obtener documentos de identidad, tarjetas a traves de theidshop, pasaporte britanico para la venta, plantilla para la tarjeta de identificacion, holograma falso pasar Identificacion, la novedad fabricante de Identificacion, Identificacion novedad plantillas gratuitas, comprar Identificacion del estudiante, pase holograma identificacion falsa, id plantillas gratuitas Identificacion de descarga, belvine, plantillas para la Identificacion, pasaporte licencia de conducir, como hacer hologramas Identificacion, hacer su propia licencia de conductores, puedo obtener un pasaporte sin un certificado de nacimiento, photoidcards.com, identificacion con fotografia novedad, como conseguir la tarjeta de identificacion, como obtener su tarjeta de identificacion, ca plantilla de licencia de conducir, pasaporte, tarjeta de identificacion, como hacer nacer certificados, la identificacion del certificado de nacimiento, como hacer una tarjeta de identificacion del estudiante, la plantilla de identificacion con fotografia, tarjeta de estudiante de la novedad, como hacer una falsificacion Identificacion facil, la conduccion de identidad a prueba de licencia, comprar hologramas de Identificacion, creado a traves de tarjetas de theidshop, id universitarios falsos plantillas
android forums
are my ringtones saved to my sd card in my ally
silverlight android
