Setting Ally to WiFi only. Is it possible????
This is a discussion on Setting Ally to WiFi only. Is it possible???? within the LG Ally Help forums, part of the LG Ally category; Setting Ally to WiFi only. Is it possible???? Just got the Ally and in two days I've used 10mb. However I've not left my house ...
Thread: Setting Ally to WiFi only. Is it possible????
    Android Lurker LilRay's Avatar
    Just got the Ally and in two days I've used 10mb. However I've not left my house and have supposedly been connected to my MiFi 2200 wireless card. I hardly leave home as I'm disabled so I got the 150mb data plan. I was told using my MiFi wouldn't accrue data usage.
    Can anybody help?
    God Bless, Ray
    Do a search here, Ray. There is a lot more info already posted. Make sure your search is set to "Forums" and not just "This Topic" or "This Forum."
    Basically, turn off sync. "Watchdog" is an App that will keep track of your usage and alarm you when the threshold is close. The search can tell you more.
android ally wifi only
configure lg ally to use wifi only
how do i only use the wifi on the of ally
how do i set up my lg ally to only use wifi
how to set verizon ally to use only wifi
lg ally data use track
lg ally data wifi only
lg ally just for wifi
lg ally set updates to wifi only
lg ally settings wifi only
lg ally wi-fi only
lg ally wifi only
lg ally wifi setup
setup lg ally for only wifi access
wifi only lg ally for international
