Voice dialing
This is a discussion on Voice dialing within the LG Ally Help forums, part of the LG Ally category; I recently switched from a Motorola Razor to the LG Ally. With my Razor, I could easily push a button, say a command and a ...
Thread: Voice dialing
    Android Lurker jeffreyholtom's Avatar
    I recently switched from a Motorola Razor to the LG Ally. With my Razor, I could easily push a button, say a command and a name from my contacts and the phone would repeat my request and then dial the contact. I have tried several apps but none seem to work very weel and none repeat my request. Do you know of any tht work better?
    Quote Originally Posted by TV Man View Post
    Have you tried vlingo? I use it daily and have had no problems with it whatsoever.
    I have read "Vlingo" is a well regarded App for taking voice commands.
    When first used, it might make a few mistakes, but it learns with use. I've been using it for about a month now, and have zero problems. The "in car" feature is fabulous.
android lg voice dial
android voice dialing voice commands
does google voice work on the lg ally?
how to voice diao on lg android
how to work voice command on ally
lg ally bluetooth voice calling
lg ally voice command
lg ally voice commands
lg ally voice dialing
lg ally voice dialing how to
lg bluetooth voice commands
voice activation on lg alley
voice dial lg 415
voice dialing on lg ally
where is voice command on lg android
