LG Ally Favorites
This is a discussion on LG Ally Favorites within the LG Ally Help forums, part of the LG Ally category; How can I edit or remove favorites from my favorites folder? When I make a call it adds the number to the favorites folder....
Thread: LG Ally Favorites
    Android Lurker Greg_lgally's Avatar
    Clear the little star in the top right corner of the contact.
    I think what you see are the frequently called numbers which appears under favorites. It can be deleted, but I'm drawing a blank on how I accomplished it last time.
    How is that done? I have tried touching the star to clear it but nothing happens.
    Mine goes on and off with a touch. This immediately adds or removes the contact from my Favorites.
    Qasar, he is referring to the freq called numbers and not favorites. You can't remove the freq called numbers without downloading an app. I think History Eraser is the app that will remove these numbers.
delete favorites contacts android lg
how do i clear the numbers in my favorites on my droid ally
how do i delete bookmarks on my lg phone
how do i getg to favorites on lg ally
how to clear favorites in lg ally
how to delete favorites on lg ally
how to remove contacts from favorites on lg phone.
how to remove favorites from lg android
how to remove favorites on lg android
how to remove frequently contacted in lg fone
lg ally favorites
lg ally favorites can't call
remove favorites lg ally
save website on android lg favorites star
what is the favorite contacts on a droid ally
