receiving double texts
This is a discussion on receiving double texts within the LG Ally Help forums, part of the LG Ally category; I downloaded Handcent SMS and really like it but every time I get a text, I get it twice. Is there a way to disable ...
Results 1 to 9 of 9
Thread: receiving double texts
    Android Lurker Blacksheardad's Avatar
    Georgia swamps
    I downloaded Handcent SMS and really like it but every time I get a text, I get it twice. Is there a way to disable the preinstalled messaging app?
    Reality is for people with no imagination!
    Turn off notifications for the stock Message App in Settings > Sounds & display.
    Georgia swamps
    If I go to the main screen settings>sound & display it has an option for notification ringtone but not for sending notifications. If I open up messaging>settings>sound&display notifications is already unchecked. But even so, if someone sends me a text I will get the notification box and then about three seconds later I will get another one. Not a big really, just a nuisance if I am trying to do something else.
    Ok, you are saying you've done this?
    Menu>applications>messaging>menu>settings>notifica tions settings (uncheck display message notifications in staus bar)
    Android Lurker nds1970's Avatar
    Oregon
    I did what Ak8s suggested except I unchecked all the options. Haven't had a issue since.
    Georgia swamps
    I'm gettin lost here somewhere. From "home screen" open menu? There is not "applications" under that menu. If I go to "settings" then I have apps but when I open that I don't find messenger there.
    I didn't think I was this dense! What am I missing?
    If you are on your home screen and you press the menu button it shows (at least on my phone) the options add item, set wallpaper, search, applications, preferences, settings. Choose applications (eyeball looking icon LOL) and go from there.
    Quote Originally Posted by Blacksheardad View Post
    1. Try opening the default message app. Press the menu button. Press settings. Scroll down and uncheck Notifications.
    Or
    2. In Applications, go into manage applications, press the menu button, touch Filter, select All. You should then see the message app in the list.
    Georgia swamps
    Thank you for your patience. That cleared it up. Thanks for the help too.
android receiving double texts
double texts handcent driod
double texts lg ally
receiving double text sms go android
