call forwarding
This is a discussion on call forwarding within the LG Ally Help forums, part of the LG Ally category; how do you enable call forwarding...
Thread: call forwarding
    Android Lurker jbelf19's Avatar
    Android Jr Member khargray's Avatar
    Information taken from the Verizon Wireless website. I have not used this feature.
    Call Forwarding
    Description
    Forward your calls to another phone number, including your home or office number. Your wireless phone will not ring until you deactivate the service. Airtime applies to forwarded/transferred calls even if you send the call to wireline telephones. When forwarding calls to phone numbers outside your local calling area, you'll be billed for any toll, long distance, and airtime charges incurred. Additional per-minute charges may apply to all forwarded calls. This feature is also known as "Immediate Call Forwarding".
    How to Get It
    Call Forwarding is an included feature that is typically added to your account when you first activate service. If you wish to confirm you have this feature, sign in to My Verizon and select "My Plan" and then select "Add/change features".
    How to Use It
    To Activate:
    1. Press *72.
    2. Enter the phone number where you want calls to be forwarded. (e.g. *72-908-123-4567).
    3. Press SEND and wait for confirmation. You should hear a confirmation tone or a message.
    4. Press END.
    To Deactivate:
    1. Press *73.
    2. Press SEND and wait for confirmation. You should hear a confirmation tone or a message.
    3. Press END.
call forward lg ally
call forwarding lg ally
call forwarding on lg ally
call forwarding verizon lg ally
call forwarding verizon lg phones
how can i forward my calls to another phone from my lg android phone?
how to call forward on lg ally
how to forward calls from lg ally
how to forward calls from my lg android
how to forward calls on lg android
how to take a phone off call forwarding
lg ally android call forwarding
lg ally call forward
lg ally call forwarding
undo call forwarding on android ally
